is the cRIO 9067 compatible with LabVIEW 2013?
I just purchased 2 cRIO 9067s and I'm trying to configure one of them to use.  I got the IP address set and booted it into safe mode.  The status light blinks twice, then pauses.  The documention says this means I need to download software.  NI MAX only suggests using versions 14.?, which I'm assuming is LabVIEW 2014, but that option is grayed out.  And if I  try to do a custom install, everything in the list produces a concfict and wont download.  Is the 9067 only compatible with LV 2014?  Or am I missing a step?  the version of LV that I am using is 2013.  I'm installing 2014 to test this theory, but I'm no thopeful.  Thanks for the help people.
(3,410 Views)
Accepted by topic author RickJames
The cRIO-9067 does require LabVIEW and NI-RIO 2014. You can use http://download.ni.com/pub/gdc/tut/crio_software_versions.htm to look up the minimum software support for cRIO products.
I don't see how I can link directly to the result, but if you select "CompactRIO Chassis and Controllers" from the drop down and then "cRIO-9067" you should see this table.
NI cRIO-9067
Minimum Software Support
SoftwareCompactRIO (FPGA Interface)CompactRIO (Scan Interface)
✔ Supported ✔ Supported
LabVIEW 2014 2014
LabVIEW FPGA Module 2014
LabVIEW Real-Time Module 2014 2014
Device Driver Software NI-RIO Device Drivers August 2014 NI-RIO Device Drivers August 2014
NI-DAQmx
Other Minimum Software
(3,400 Views)
That answered my question.  Thank you.
(3,379 Views)
