is the labview 8.2 can genarate or synthesis using VHDL or verilog software ?
hi
i designed system using labview 8.2 now i want to install the design on the FPGA kit
i found thats the FPGA (altera) is not compatible with labview
how i can genarate VHDL or verilog code or synthesis the labview design
thank you
(2,482 Views)
Hi mouath,
               I suppose u need have ni's FPGA with ni's fpga tool kit installedSmiley Wink
(2,477 Views)
Hi mouath,
In order to program an FPGA with LabVIEW you will need to use the LabVIEW FPGA Module.  What hardware are you trying to target?  The LabVIEW FPGA module lets you compile LabVIEW code into a bitfile, when can then be written to an FPGA.
Brian A.
(2,447 Views)
