is there a race condition between events and newValue in case?
Hi Humm,
You would definitely not waste your time if you took some minutes to read the online LV help for the Value (Signaling) property node !
Message 11 of 12
(548 Views)
GerdW.
I used them to see if they would introduce any additional "history" or delay or potentially be a cause for what I was seeing.
Thanks for the Rube Goldberg...your absolutely correct about that.
Others:
Thanks for the reference to the fundamental help.  I have been using non-latching switches as the front end on my Vi's since that enables pressing a button, having some things happen due to an event...and at the tail end of the event resetting the button as being ready for use again.
Thanks to all.  This is a big help.
The Hummer
Message 12 of 12
(531 Views)
