is there an example problem for calculating absorption coeff. ?
I needed to create a labview program to calculate the absorption coefficients for foam samples from impedance tube.
What I needed to do is to create white noise for the speaker, read in the pressures from two microphone averaged for
15 seconds, and calculate the absorption coefficient. I suspect this to be very common and wanted to find out if there
is an example on something similar.  Thanks, Zakir (734) 779 7125 office
(2,422 Views)
I have replied to this at:
http://forums.ni.com/ni/board/message?board.id=170&message.id=144533
Sincerely,
Minh Tran
Applications Engineering
(2,406 Views)
