is there any possibilities to display value in LCD using SBRIO 9638?
“I want to use a standard 16×2-character LCD with the sbRIO-9638. Can you confirm if I can drive this display using the digital I/O lines on the sbRIO-9638 FPGA, and if LabVIEW FPGA is suitable for implementing the required control signals (RS, EN, D4–D7)?
(129 Views)
Hi Ajay,
  • What exactly is a "standard 16×-character LCD"? Can you provide a specsheet describing the input signals of such a "standard LCD"?
  • The sbRIO9638 spec is found here
  • The sbRIO9638 provides 28 "5V tolerant" DIO pins: that should be sufficient to drive your 6 digital lines…
(99 Views)
Yes, you can use NI LCD Module Driver with HD44780-based character LCDs.
https://tmesystems.net/
(95 Views)
