is there any possible software for converting embedded C program to labVIEW?
(2,894 Views)
Not that I know of, that would be cool though.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,893 Views)
SO wat are the other possible ways to convert it to labVIEW?
(2,891 Views)
- reprogramming in LabVIEW
- using the formula node you can type code in a "similar to C" syntax
(2,888 Views)
Embedded C is quite a broad term. Do you refer to a specific lightweigth C dialect or to simply some code used in embedded systems? In the first case I think it will be hard to do any easy integration into LabVIEW without manually translating the code. In the second case you may be able to get away with compiling the code into a shared library and import it into LabVIEW like that, by using the Call Library Node.
Rolf Kalbermatter  My Blog
(2,884 Views)
