is there any way to change waveform generation using formula with user defined formulas
I need to build a VI that has in input a formula (Ex:Sen(w*t)) and output a waveform.
The waveform generation using formula.Vi that comes with labview has Defined formulas and theu are not dinamic I don't want that.
I try to change with a text control but VI dont generate the graph.
Can someone help me with this please?
Best regards
Ricardo
(2,701 Views)
Hello.
If you want to change your formula with a textbow, you can use the Eval Formula Node.vi if you have a full version of LabVIEW.
see http://digital.ni.com/public.nsf/allkb/C5DBAA3A788271EE86256B02007DD6B3?OpenDocument
Best regards
(2,677 Views)
