is there any yaskawa labview drivers for ac drive j1000.
is there any  yaskawa labview drivers for ac motor driver j1000.
(2,833 Views)
Hi kaurtej.
You do not provide much information on what kind of hardware you have. However here are some generel information about Yaskawa V1000.
I have found an old topic regarindg this motor. Let me qoute 'LV_Pro':
Taking a quick look at the manual online it appears that this drive controller is communicated with using MODBUS over a RS485 serial link. There are a number of companies that make RS485 to USB serial adapters, (...). There is a MODBUS Library of LabVIEW vi's that provides the Modbus functionality. You will be able to select the comm port that is created when the RS485 adapter is installed in these Modbus vi's.
- http://forums.ni.com/t5/LabVIEW/how-can-i-control-a-Yaskawa-V1000-variable-frequency-drive-with/td-p...
You can get a RS485-to-USB here:
https://www.ni.com/en-us/shop/model/usb-485.html
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(2,826 Views)
sir i have to control the speed(rpm) of ABB 3 phase AC motor in real time through PC using labview .i had heard that yaskawa do provide with labview driver for ac drivers.
i had decided to use usb copy unit of yaskawa driver(j1000) for controlling it through PC using drivewizard software.
(2,819 Views)
