is there something wrong or missing in measurment and autimation explorer?...please help
hello every one..I'm using measurment and automation v4.5 and i took this path :  Tools » RT Disk Utilities » Create Desktop PC Utility USB Drive ...but i found out that Create desktop utility USB drive is hidden option...i mean inactive..just like something is missing or wrong, and all options in this sub-menu are inactive....could any 1 plz tell me the reason and how to solve this probelm..know that am using labview 8.6 with real-time installed and i wanted to create a another pc as a real time target using this utility to run the check test 1st....please help me in this....
by the way:- i used 4 GB USB disk......+ Real time module is not installed on my PC,do i have to install it to get this option (Active and shown in this menu)?
thanks a lot in advance
(2,925 Views)
You have to install the Realtime module as I contains the components required for those options to function.
Let me know if this helps
Philip
Philip
UK Branch
===If this fixes your problem, mark as solution!===
(2,855 Views)
You need to install the rt utilities
(2,852 Views)
