isit any option to add comment in excel using report generation toolkit
kavi
(3,168 Views)
Did you check all the properties & methods?
- Partha ( CLD until Oct 2027 🙂 )
(3,161 Views)
yes i tried with active x but how to do with report generation
kavi
(3,156 Views)
Hi kavi,
do you have a solution with ActiveX? If yes, then you can write your own vi, which uses the Report Generation Framework. You can then use the Refnums from the internal of the Report Generation.
Mike
(3,142 Views)
yes.fine
kavi
(3,136 Views)
