iviConfigurationstore.xsd missing
I am a little desparate now.
I was a beta tester for LV7. When the final release came up I uninstalled my complete set of NI SW and installed the whole package new from my DevSuite TestEdn. This started three weeks ago and still I am having trouble with MAX an other components.
At the moment MAX can not 'deserialize' the viConfigurationStore.xml, because the XML schema file iviConfigurationstore.xsd is not found. It should reside in :\Programs\IVI\Data\iviConfigurationstore.xsd . The same problem is reported by the NIDMM driver front panel.
I have tried to repair my NI-DMM driver with no luck. I have searched for that file locally, on my CD set and on NIs homepage - with no luck either.
Can anyone of you send this file to m
e?
In case it is important:
* The whole set of HW did operate with the beta SW, so there should be no HW problem.
* My system: W2k German, SP2 on PII/450 with 448MB of RAM
* Develloper Suite Test Edition as of May 2003, which is
- MAX 3.0.0.3014
- LV 7.0 PDS
- NI-DAQ 7.0.0f8
- NI-DMM 2.1.1
- IVI Engine 2.0.0
- IVI driver Toolset 1.5
- IVI Configuration server 1.3.1.0
Any help is apreciated!
Message 1 of 1
(2,584 Views)
