j k flip
hi
i am try to built a j k flip flop like figure below with out the clock i get always an unstable state
i search in ni i found some   j k flip.vi  but it complex
i find that shift register both at first execute false and this wrong in sequential logic i try to solve it but another problem appear
what i can do to problem ???
Best Regards
hi ?Q>
(3,715 Views)
Hi mangood,
                    I can't view your VI as Iam using LV2009.Anyway Here is a good example:-
                    TTL.zip 108 KB
Thanks as kudos only:)
(3,703 Views)
Accepted by topic author mangood
Hi mangood,
you already have a transistion table. Why not use a simple case structure and only one feedback node for that task?
Simple boolean math will do it too:
(3,684 Views)
thank you for Smiley Very Happy
both  Replies help me alot
hi ?Q>
(3,639 Views)
