k-means classification
I want to perform a k-means clustering with some 1D-arrays. The arrays are to be sorted into different groups which are generated during the clustering process. I already found that the NI Vision Development Module is something that could help me. Has anyone experience in k-means clustering under LV?
I'm very interested in your answers!
(5,591 Views)
Hy asdkamps,
The vision development module brings Classifiers with it. But it works on images and all of the classifiers there have to be trained. A k-mens could be done with customer classifiers, but I think it´s less work for 1D arrays to programm it without the vision development module.
I assume the 1D array is a vector in n-dimensional space and the distance functino D is euclidic distance?
Maybe the following paper is also of use, there k-means is used in LabVIEW.
http://edt.missouri.edu/Summer2005/Thesis/PogulaS-072105-T2944/research.pdf#search=%22%22k-means%22%20labview%22
Peter Griese
NI
(5,554 Views)
Hy,
If you give me an email adress can get you in contact with a developer who works on k-mean implementation, he will propably be able to help you.
Peter Griese
NI
(5,532 Views)
Hello Peter,
thank you very much for your information. The link seems very promising but I will need some time to work it through.
Yes, you are right, the vector is n-dimensional (n=400-600) and the distance function should be euclidic.
Right now, my e-mail adress should be visible in the public user information. I'm very interested in discussing with the developer who works on k-means implementation.
Message Edited by asdkamps on 09-14-2006 02:11 AM
(5,525 Views)
