k-nearest neighbors in MLT - any example?
Thanks for the reply! I meant to say I am new to manipualating arrays in labview. I figured a way out to give the input(training data), via read from spreadsheet and then via array to cluster. I keep getting error 1026 though, which says some VI reference is invalid.
Vysh
Message 11 of 13
(953 Views)
Hi guys,
I'm trying to implement k-nn to distinguish two separate classes of EEG samples(Right and left). I have obtained the AR coefficients for both the classes but I have no idea how to make the Knn in the MLT function? Any examples as to how I should proceed?
Message 12 of 13
(916 Views)
Thank you for the question. If you have a question concerning specifics of the MLT algorithm as opposed to general LabVIEW functions, I would recommend creating a new thread for this issue. This particular thread has been open for quite some time. As this particular application is supported mainly on the forums, starting a new post will provide better visibility for your issue.
Best Regards,
Message 13 of 13
(896 Views)
