‎06-07-2007 04:11 PM - edited ‎06-07-2007 04:11 PM
Message Edited by unknown00 on 06-07-2007 04:18 PM
‎06-07-2007 06:41 PM
‎12-16-2008 10:31 AM
I have encountered the same probelm when using the lvanlys.dll in a pgm. What I found is it does get included as one of the dependancies and put into the correct sub folder. However if yuo read how LV handles DLL's it says that it only includes the top level DLL and if that DLL calls other DLL's you will have to include those manually. I tried to read the lvanlys.dll in notepad to see if it calls other DLL's and there are several other DLL filenames in there. I included all of the DLL's that I could find but there were still some that I couldn't find and it still doesn't work. The bottom line is I don't think the lvanlys.dll will work in an exe until we know all of the sub DLL's it calls and are able to manually include them in the build. I don't think building an installer version of the EXE will work unless it includes all of the missing DLL's. Also I don't want my users having to install everytime they want to use the EXE.
DWH
‎12-16-2008 10:51 AM
You are incorrect about using an installer. That is the best way to get all of the necessary files. It should be run at least once. After the correct support files are installed, you need to only update the exe if necessary.
‎12-16-2008 12:05 PM
Sorry about my inexperience with an installer. I haven't used this feature. I will read and learn how to use then see if it can solve the problems.
DWH
