keep the same plot color for a multiple XY graph
Hi everyone,
I want to plot the last 5 plots on the same XY graph with differents colors. For this I am using a shift register. Using shift registers makes the plot colors change.
ex:
Imagine I choose plot 1 to be red,  plot 2  orange and plot 3 yellow ( XY graph properties )
when I start the VI this is what happpens
 First iteration plot: red
Second iteration plot: red
first iteration plot: orange
third iteration plot :red
Second iteration plot: orange
first iteration plot: yellow
The shift register makes the plot shift to the bottom making the new plot always in red.
what if I want the plot to keep the same color even if they are shifded? ( first iteration plot always in red and the second in orange ... )
Thanks in advance,
Message 1 of 10
(5,599 Views)
Use Replace Array Subset to replace a plot.  Use the i and Quotient & Remainder to determine which plot to replace.  This eliminates the need for shifting.
Message 2 of 10
(5,579 Views)
Attach your VI so we can see how you are building things into the shift register..
My guess is that you are using build array and putting the new plots at the beginning of the array rather than the end.
Message 3 of 10
(5,574 Views)
Here is an exemple of the VI I have right now.
F
Message 4 of 10
(5,495 Views)
You made that much more complicated than it needed to be the way you were using multiple shift registers with history.  It was bascially like I was thinking where you wree building the arrays backwards.
Just use Build Array on the graph data and a single shift register.  See attached.
Also, when you run a while loop N number of times, you should be using a For Loop
(PS.  It helps to put data into the controls as default so that all we have to do is click the run button and see stuff happen.  Your empty array meant nothing happened when I first tried your VI.)
Message 5 of 10
(5,488 Views)
Oh that is nice..
Thanks very much.. ...How can I fix the plot number to 5 please?
F
Message 6 of 10
(5,480 Views)
I don't understand what you are asking for.
Message 7 of 10
(5,476 Views)
I only want to plot the last 5 graphs..
For exemple: if I generate a 6th plot, it will overwrite the first
                        If I generate a 7th plot, it will overwrite the second ......
The main thing is to have 5 plots max! Thanks in advance.
F
Message 8 of 10
(5,467 Views)
Accepted by topic author feriel0209
Then initialize an array of 5 plots.  Use Replace Array Subset to replace each plot in order.
Message 9 of 10
(5,463 Views)
Thanks, this is what I need :Smiley Happy
F
Message 10 of 10
(5,454 Views)
