keithley 2000 with AD007
I am new to LabView and am attempting to write a program that will record data from a keithley 2000 digital multimeter. So far I can only send "one-shot" commands to read the data. However, my expermiment requires readings to be taken many times a second. I am communicating with the multimeter via a AD007 Tektronix GPIB Lan Adapter. The LabView version I am using is Labview 6.1. If anyone has any idea on how to send GPIB commands to the multimeter using a labview interface, it would be GREATLY appreciated.
Robert
(3,084 Views)
Are you using a driver? There should be a driver for it on your LabVIEW Instrument Driver CD or you can download one from here. There is an IVI and a LabVIEW driver. The IVI DMM class has a Read Multi Point that is probably what you want to use if the instrument supports it.
(3,084 Views)
I downloaded the drivers for the multimeter and the switch. The drivers for the switch work great; however, I am having some issues with the multimeter still. I downloaded the IVI compliance pack and installed it. It says that it is not compatable with MAX 2.6 which is what I use and says I need 3.0 in order to use IVI class drivers. Is there anyway to run the multimeter without having to install MAX 3.0?
Robert
(3,084 Views)
I'm not sure what's in this driver that requires IVI 2.0. I use other IVI drivers with 1.83 that you can get Keyword Search: Keithley. If that doesn't work, you could try the LabVIEW driver for the same instrument.
Message Edited by Molly K on 02-18-2005 11:55 PM
(3,085 Views)
