keithley 2007 settings conflict
I'm using the Keithley 2700 with 7702 switching modules, attachment are the LV(8.6) driver and  error picture.
(4,597 Views)
Accepted by topic author longzeng1981
does it happens as soon as you launch your program, or when you want to perform your measurements ?
maybe you could find some help here :
http://forum.keithley.com/phpBB3/viewforum.php?f=13&sid=898e6ef7d9532967876d205cb8bf5aaf
(4,590 Views)
attachment is the error VI
(4,580 Views)
did you tried to reset the keithley and perform a self-test ? (those two VI should be in the driver package)
(4,568 Views)
yoz'st
         thanks for your help, I reset the keithley and perform a self-test ,the 2700 didn't return error, I find to choose  "DC Voltage" in the function A, the 2700 didn't return error, but I choose the other item, the 2700 return error, attachment are the picture and VI.
(4,562 Views)
Heyy Zeng,
I am facing the same problem. I can measure the DC Voltage but as soon as I try to measure something else i get the same error -error 221-settings conflict.
Were you able to find a solution for it ?
(4,059 Views)
