keithley 2182 and Keithley 2400 Trigger link
hi guys
Solved one problem regarding the 2400 and stuck in another.
I am trying to make delta measurements on the keithley 2182 while sourcing from the Keithley 2400. But for some odd readon I am getting "Query interminated" and "trigger deadlock " on the 2182. There is no masurement being made. The program is a near exact replica of the one given in 2182 manual , repeating it for your reference
 CALL SEND (7, “:syst:pres”, status%) ‘ 2182 - System preset ‘ defaults.
CALL SEND (7, “:trig:del 1”, status%) ‘ 2182 - 1sec delay.
CALL SEND (7, “:sens:volt:delta on”, status%) ‘ 2182 - Enable Delta.
CALL SEND (7, “:syst:faz off”, status%) ‘ Disable Front Autozero to ‘ double Delta speed.
CALL SEND (7, “:trig:sour ext”, status%) ‘ 2182 - External triggering.
CALL SEND (7, “:trac:poin 3”, status%) ‘ 2182 - Buffer size 3.
CALL SEND (7, “:trac:feed:cont next”, status%) ‘ 2182 - Enable buffer.
CALL SEND (24, “*rst”, status%) ‘ SM - RST defaults.
CALL SEND (24, “:trig:sour tlin”, status%) ‘ SM - Select trigger link.
CALL SEND (24, “:trig:dir sour”, status%) ‘ SM - Enable source bypass.
CALL SEND (24, “:trig:outp sour, status%) ‘ SM - Output trigger after ‘ source.
CALL SEND (24, “:trig:coun 6”, status%) ‘ SM - Trig count 6.
CALL SEND (24, “:sour:func curr”, status%) ‘ SM - Source current.
CALL SEND (24, “:func ‘volt’”, status%) ‘ SM - Measure voltage
CALL SEND (24, “:volt:nplc 0.01, status%) ‘ SM - Fast measurements
CALL SEND (24, “:sour:list:curr 10e-6, -10e-6, 20e-6, -20e-6, 50e-6, -50e-6”,status%) ‘ SM - Current list values
CALL SEND (24, “:outp on”, status%) ‘ SM - Turn output on.
CALL SEND (24, “:sour:curr:mode list”, status%) ‘ SM - Enable list mode.
CALL SEND (24, “:init”, status%) ‘ SM - Start sweep.
My Program is attached below. can you suggest what is the problem. This is the first time I am using the trigger link feature in 2182 and 2400!!
(5,709 Views)
As in your other thread, why you are not interested in using LabVIEW drivers? They are handy and simple enough to complete your requirements.
(5,706 Views)
Accepted by topic author Runge
Hi all
Problem nearly solved
I  am attaching the file that I got from Keithley's website .
Since I have to modify to incorporate the magnetic field variation. it is a bit messy. But still it does the job and works perfectly fine.
It stands as a good basis for triggering any Keithley SMU using Keithley 2182 using the trigger link line
Runge
PS: Mathan
I have written a lot of program for Keithley 6430  Keithley 236 etc in the past couple of years. But the VISA drivers always had a problem. Since I had encountered a lot of em in the past, I have swtiched over to GPIB SCPI programming where u r in control of the code and can troubleshoot easily.
Anyways for starters the VISA drivers are a wonderful tool
Thanks for your tip Smiley Wink
(5,680 Views)
