keithley 238 VI
Hello
I am using this VI(attached below) to control keithley 238 using labview 8.6 through a NI-GPIB-USB HS adaptor.  This VI sweeps the voltage from "start voltage" to "stop voltage" in increments of  user programmable number of points.  The VI then records the current measured by the keithley 238 , for each voltage point, in the form of a graph as well as a table.
I typically use 1V per point. So initially i sweep from 1V to 10V though 10 points, and it works very well. However at higher values, like 1V to 60 V, if i put in 60 points, i dont see any current data measured and recorded. If i put less points, say 30, it works.
Once it doesnt record data, which happens if i put more points,  the VI stops working  completely and i must restart it again.
Could you please help me out with what is wrong and what should i change.?
Regards and thanks
poli
(3,253 Views)
I dont have one of these instruments to test, nor a manual of their operation, but the main thing is that you monitor the error terminals.  Are you recieving any errors?  It looks like you have an indicator for your error terminals, so you should see any. Have you tried running this in highlight execution or step through the code to see exactly where it freezes up?
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(3,217 Views)
Dear poli,
Did you get the serial polling to work at the end of sweep?
(2,580 Views)
