keithley 2750 multimeter excel data logging
The one thing that pops out is the stop button inside the case statement. Place it outside so you don't have to wait five minutes for the program to stop.
Your question about a vga adapter makes no sense. You must have a serial port. USB converters are cheap.
Message 11 of 16
(1,514 Views)
@Deeee wrote:
So, this is what I ended up with, do you know if there will be issues if I have to use a rs232 db9 to vga adapter to run on a laptop without an rs232 db9 port?
Imagine, you connect your wash machine to the gas pipe instead of the water pipe. Would it work? It may even blow up...
https://en.wikipedia.org/wiki/RS-232
https://en.wikipedia.org/wiki/VGA_connector
This is what you need:
http://www.usb-serial-adapter.org/
Message 12 of 16
(1,502 Views)
Thank you both for taking time to help, I learned a lot. Also thank you for your patience.
Message 13 of 16
(1,483 Views)
hello Dennis,
So I got the serial to USB adapter and the program runs until I get to the configure measurement, I attached screen shots. The configure measurement vi error says that the hardware is missing.
Message 14 of 16
(1,463 Views)
Is the channel list valid? That's an error reported by the instrument.
Message 15 of 16
(1,452 Views)
Yea I got in contact with them, I didnt realize that you needed a seperate multiplexer card added to one of the slots of the unit I thought you were able to pull data just using the rs232 on the back of the unit. It reports missing hardware because you need a seperate multiplexer card added.
Message 16 of 16
(1,415 Views)
