keithley 6430
Right click on the error indicator and select 'Explain Error'.
Without seeing the code, can't give any real advice except perhaps increasing the read/write timeout setting.
Message 11 of 12
(902 Views)
Thanks for your answer. it works now, but i still have problem with read.vi  and write.vi because i can't read the mesure value, and for the writing, the Keithley 6430 generates the zero value and the span value, but i can't modify the generated value with a command for varying the power supply output. I would really appreciate your help.
MESURE
SOURCE
MESURE
Message 12 of 12
(886 Views)
