keithley kusb-488A and Labview
I'm using a keithley GPIB kusb-488A to control a keithley 487 Picoammeter, and I'm having some problems with it interaction with labview.
I'm using LabVIEW 2010 and the GPIB driver from Keithley (version 9.2).
When I run the program "GPIB Diagnostic", everything is ok, but when I try to run my program it don't write the voltage in the device. It seems to read ok, but write wrong. I don't understand why, because this program runs ok in another computer in a older version of labview and GPIB driver.
Thanks for all your help,
Sílvia
(3,828 Views)
Hi Silvia,
Could you post the VI(s) of the the "GPIB Diagnostic" program and of your program ?
Also could you tell me which older version of labview your program runs ok with ?
Ludovic
(3,795 Views)
Hi Ludovic,
"GPIB Diagnostic" isn't a Vi, is a program from keithley which permit do a test to the device. And that test it's ok.
In the other computer I use a labview 8.0 and a GPIB driver from Keithley (version 8.3).
Now I can't put here my vi, but tomorrow I'll post.
Sílvia
(3,775 Views)
I send attached my vi and the library for the keithley 487.
Thanks for the help,
Sílvia
(3,759 Views)
I already solved the problem. It was related with the regions configurations, because I use "," instead of ".".
Sílvia
(3,755 Views)
