kepco BOP488 driver field sweeping
Hi All,
I need desperately a help. I have a kepco BOP488 device to be used in some measuremnts whose instruemnt is installed already. The options that driver gives not proper for me, for instance ; driver front panel allows one only set a certain power out put, but what i want to do is sweeping the field in between different polarity. ( set 0 V and wait , set 1V wait, set 2V wait......set-1V). In order to do so, i had the idea of changing writing strings but completely confused due to the fact that there is no writing and reading VIs. Could you have a look to attached and can you help me which subVI i should modify.
thanks
(2,504 Views)
I don't know what you mean by "no writing and reading VIs". There is the GPIB Write that sends the command to the instrument. I haven't used this instrument but if you want to increment the voltage, can't you do that by changing the value you pass to the 'VOLTAGE' input? Put this function in a loop. Your step values could be an array or from a shift register that gets incremented, etc. Unless the instrument has a command that supports some sort of sweep operation, you have to do it in your program. Check the manual for the instrument.
Message Edited by Dennis Knutson on 02-12-2007 11:42 AM
(2,498 Views)
