kernel.cpp DWarn: why no caller in VIExit
I have a LabView 8.20 VI which crashes at random points with the log below.  Is this an issue with the coding, the labview install or something else?
Thank you,
Charles
#Date: Tue, Sep 04, 2007 4:50:11 PM
#OSName: Windows NT
#OSVers: 5.1
#AppName: LabVIEW
#Version: 8.2
#AppKind: FDS
#AppModDate: 07/27/2006 17:08 GMT
.\exec\kernel.cpp(810) : DWarn: why no caller in VIExit
$Id: //labview/branches/Europa/dev/source/exec/kernel.cpp#13 $
0x00C5DC93 - LabVIEW <unknown> + 0
0x08B0FBFC - <unknown> <unknown> + 0
0x051217FC - <unknown> <unknown> + 0
0x00C4BE60 - LabVIEW <unknown> + 0
0x000594EC - <unknown> <unknown> + 0
(2,719 Views)
Hi Charles,
You can try repairing the LabVIEW installation.  Go to Control Panel >> Add/Remove Programs >> National Instruments Software and then select your version of LabVIEW in the pop up dialog.  Select repair.  If you can post your code, I'll try it on my computer as well.
Thanks!
(2,705 Views)
