kernel32.dll
Hi all,
I'm trying to use the Call Library Function VI to call GetKeyboardState
from kernel32.dll as suggested below. I put the VI on my diagram and
right click to configure. Then I pick the dll from the
c:\windows\system directory. It gives me a list of functions in the dll
to choose from but GetKeyboardState is not one of them. I'm using
Windows95 and the version of kernel32.dll is version: 4.03.1212. Do I
have an old version of the dll?
Has anyone had success using this function call from this dll? Also, if
this is a result of an older version of the dll, is it possible to just
copy the dll from a Windows98 box? Will that screw other things up?
stephen
>Hi,
>You could use de windows dll GetKeyboardState (kernel32.d
ll) to monitor
if
>ALT+key is pressed. It is not ideal, because it requires a while loop
to
>call this dll all the time. If a key, mouse button, or combination, is
>pressed, you can trigger a boolean, or whatever you want.
>To call the dll, use a numeric 8 bit as output, stdcall(WINAPI) as
calling
>convention and a 8 bit array as first (and only) argument (with Array
Data
>Pointer as Array Format). Wire a 8 bit array to argument1, filled with
256
>dummy values. If a value is pressed, the corresponding array element
changes
>to 128.
>Regards,
>Wiebe Walstra.
>AIR technical Automation
>www.air.nl
>"Stephen Gray" wrote in message
>news:39F735F4.2BD9EA8A@swri.org...
>Does anyone know of a way that I can attach the keyboard sequence
>F10 to a control in Labview. I've used the key navigation
>successfully to make use of the Control and shift modifiers, but I
>REALLY need to use the modifier. Anyone know of a work around?
>BTW - I'm using Labview 6i u
nder Windows95.
>Thanks,
>Stephen
(4,770 Views)
According to the MS Site, getkeyboardstate is in user32.dll, not
kernel32.dll. I'm not in a postition to check who's right, at the
moment...
Stephen Gray wrote:
> Hi all,
> Thanks,
> stephen
> >Hi,
> >You could use de windows dll GetKeyboardState (kernel32.dll) to monitor
> if
> to
> calling
> Data
> 256
> changes
> >to 128.
> >Regards,
> >Wiebe Walstra.
> >www.air.nl
> >BTW - I'm using Labview 6i under Windows95.
> >Thanks,
> >Stephen
(4,770 Views)
I'm terribly sorry, it is User32.dll. I'll mail you (Stephan) our
implementation to make it up...
Wiebe Walstra.
www.air.nl
"Bruce Bowler" wrote in message
news:3A01D868.A0B6348E@bigelow.org...
moment...
Stephen Gray wrote:
> Hi all,
> Thanks,
> stephen
> >Hi,
> if
> to
> calling
> Data
> 256
> changes
> >to 128.
> >Regards,
> >Wiebe Walstra.
> >www.air.nl
> >Thanks,
> >Stephen
(4,770 Views)
We've added GetKeys.vi to our library. If anyone's interrested, feel free to
download it...
Wiebe Walstra.
(4,770 Views)
> moment...
Could you post the URL to the place on the MS Site? I have not been able to
find it.
Ed
(4,770 Views)
