key down event to start something an stop arbirtrary
hallo,
what I'm trying to do is to start an event on key down an do a loop , something like move an axis for CNC , and this until i press an arbitrary key again.
i have already a while loop an an event structure so it would be good just to add something withtout large modifications.
have anyone an example code for me , please.
i've looked already in a lots of posts but i can't find anything usefull for me.
many thanks in advance
(3,019 Views)
Use the event for <vi> Key Down.  Check to see which key was pressed, then create a case to handle the appropiate keys.
LV7 example attached
2006 Ultimate LabVIEW G-eek.
(3,017 Views)
thank you but it just say a or not a ,what i want is a loop in this event which which will be executed till the next key is pressed so it ist unknown how many times this loop will be executet. i dont know how to handle this.
i can do what i want just 1 time and then i have to press again a key , but it should run until a key is pressed.
something linke in C:
while ( !kbhit() )
do something
(3,010 Views)
there's probably lots of way to do this - if you want to maintain the event/while loop structure, you could use a Master/Slave method.
LV7 examlple attached.
(3,006 Views)
this is exact what i wanted. thank you.
is there also a possiblity to start and stop with the same button  for ex. "a ".
regards,
Patrick
(2,995 Views)
again - lots of ways to do this.
The attached example is just the fastest I could modify the previous version Smiley Happy
(2,988 Views)
