key toggle is not working in vi called in a sub panel
Hi all,
I am using LabVIEW 8. I am calling a sub vi in a sub panel of Main caller vi. Toggle key is not working in called vi like Exit on Escape button. but if i run this sub vi on it's own. (without calling it from anywhere) then it works.
More over i am using event structure and using many events... then why does it show ascii value 0 for many keys??? like escape, delete, pointer keys...etc.
-Alok
-AL☼K
(2,935 Views)
Hi Alok,
I am having a hard time understanding the issue you are facing. Can you please describe the problem with more details and it will help if you can put in a screen shot as well. Thanks and have a great day!
Prashanth
(2,918 Views)
Hi all,
sorry for the long escape.....but i'm back. thankx for your reply prashanth sorry i was stucked with other deadline.
now i am sending sample VIs stating my problem better.
When i call a vi in a sub panel, it's key toggel property fails. when it is run own it's own then no problem and it works.
can i use these property with using subpanel (I am using it just because LabVIEW does't have child window property)
moreover can i shift keyboard tab order from called vi to main or vice versa.
-Alok
-AL☼K
(2,878 Views)
Hello Alok,
You should things different have a look here
 ANd have a look at the examples on sub-panels
Ton
My LabVIEW Ideas
(2,869 Views)
