keyboard navigation with left right keys for a ring
is it possible to use the left/right keyboard keys to control a ring? They do not appear in the keyboard-navigation properties.
It has to work that way, that I can move with the keys through the ring-entries and select the desired entry with <enter>
Many thanks in advance,
                    Magnus
(3,228 Views)
Hi Magnus,
This is not the only way, but I think this is the easiest... use an event structure to detect a keystroke, and if the pressed key is the one you want, update the value of you ring 😉
Message Edité par TiTou le 12-12-2006 10:29 AM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,228 Views)
Hi TiTou,
thank you very much!
Just one more thing: if I press now the key, the new value for the ring is immediately active. So you can only jump to the next or the previous element.
I need the function in the same way as if you click with the mouse on the ring, all ring-elements are shown and then you can select one element.
Any idea?
Thx,
          Magnus
(3,208 Views)
Hi Magnus,
Sorry, I haven't found how to do exactly what you're asking for... I made a small VI in which if you press "left" or "right", the ring gets the "key focus" and then you can "scroll" the value with the up/down arrow, but you can't see all the value like if you actually clicked on it...
Hope this helps... 😉
BTW, I don't know in which context you are using LabVIEW, but this point is - IMO - not worth spending hours 😉
Epictetus
Antoine Chalons
(3,201 Views)
