keypad.vi dsk6713
hi,
i m using labview dsp toolkit . 2 and labview 8.5
in the user manual 323452a there is example of of keypad , i need tht  keypad vi
i m using TMS 320C6713.
(3,783 Views)
Hi Ezeemon,
Do you have the DSP module or the DSP Test Toolkit?  The Keyboard.vi should be included with the DSP Test Toolkit.
Stephen S.
1 Test is worth 1000 expert opinions
(3,739 Views)
yes, i have but  tht keypad vi is  for C6x11.i need tht for C6713.
tht for tht i have to change audio.cdb i need tht
thanx
(3,729 Views)
Hi ezeemon,
I'm not sure if they VI exists for anything other than what it is used for in the example.  I'll see what I can find though.  Thanks.
Stephen S.
(3,700 Views)
Hi ezeemon,
The vi's that are in your toolkit are the only ones that we distribute as NI supported and developed products.  The keypad.vi example is designed for the TMS320C6711 or TMS320C6211.  You may be able to modify the vi to work for the 6713 but it is not a vi that National Instruments provides.  Sorry for the inconvenience.
Stephen S.
(3,666 Views)
