kind of buffer problem
Hi out there!
Me again..
I have a programmately problem. I attached an analogous program to my real.
A special hardware sends data in portions with no sending data between the portions.
I want to collect the portions into one array in an parallell loop.
See file for more information.
Thanks Fredda
Message 1 of 9
(4,049 Views)
The wait function in loop 2 should be 50 ms!
I forgot to change.
/Fred
Message 2 of 9
(4,039 Views)
Hi Fred
You can use a queue:
loop 1: enque elements 1 by 1
loop 2: dequeue 1 elements
Take a look at theese links:
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B123AE0CB9B9111EE034080020E74861&p_node=DZ52071&p_submitted=N&p_rank=&p_answer=&p_source=External
http://zone.ni.com/devzone/conceptd.nsf/webmain/C54BADADD8BBDE4286256C5200533B80?opendocument
Hope this helps
Alipio
"Qod natura non dat, Salmantica non praestat"
Message 3 of 9
(4,034 Views)
thanks, but cant see how this helps me?
/Fred
Message 4 of 9
(4,025 Views)
if your problem is the fact that your file "all.txt" is blank
try with this solution :))
Message 5 of 9
(4,018 Views)
You probably should carefully rethink your overall program design, but here is a quick and dirty solution to give you some ideas:
Remove the timing in the second loop, but place an event structure triggered by the number. In loop one, write to a signaling property of that number to trigger the event whenever new data occurs.
See attached (LabVIEW 7.0).
Message 6 of 9
(4,005 Views)
Hi Fred
Well, perhaps I didn´t understand your problem.
I think the solution could be "queues". ( don´t care about file writing)
Greetings.
Alipio
Message 7 of 9
(3,993 Views)
Hi!
thanks for your tip!
The only problem is that the arrays from both loops in filewrite(open the writefiles)
differ a little. The second loops array doesnt exactly follow the array values from loop one!
Why?
Take a look at my attached file
/Fred
Message 8 of 9
(3,978 Views)
HI!
Could you please describe in detail how you
used the property node for my program, dont get
how you made it work. Have not used it before.
/Fred
Message 9 of 9
(3,972 Views)
