krearrange row matrix
Hi, I have problem in rearrange back the row for matrix based on my instruction. For example let say we have 5 row and 5 column
 a b c d e
 f  g h i  j
 k l m n o
 p q r s t
 u v w x y
so, i want to get row 1 jump to row 3, row 3 jump to row 2, row 2 jump to row 5 and so on. Can somebody help me?
(3,134 Views)
Hi jepsepah,
you should use IndexArray to index rows from your input array and ReplaceArraySubset to move those idnexed rows to their new position.
"i want to get row 1 jump to row 3, row 3 jump to row 2, row 2 jump to row 5 and so on."
Is there any hidden scheme in those repositioning algorithm or just random order?
(3,129 Views)
If you have the order defined then you can use an Index Array and For loop to do the Job.
(3,125 Views)
Thanks GerdW and P@Anand for your replies. I have tried P@Anand method but its look like I have got a transpose matrix as attach
(3,111 Views)
GerdW, the arrangement of row is important to further my project analysis. So, each row have their own characteristics.
(3,109 Views)
Remove auto indexing of the 2D DBL array coming into the FOR loop.
and then, remove Build arrray function after index function
Regards
Freelance_LV
TestAutomation Consultant
(3,104 Views)
TQ Freelance
(3,082 Views)
