lab view code generation failed
Hello
I am new with the Labview..
It was working fine like some days ago..
But was trying to fix my Basler Camera to work with Labview..
I update the all the recommended updated suggested Lab View and MAX..
Well it didn't make my Basler Camera work but I found new error which say"Lab view code generation Failed"
Please tell me the solution for this...
I have uploaded the image too
!...aXe...!
(2,607 Views)
Hi !...axe...!
It sounds like you've managed to configure your system with an incompatible combination of LabVIEW and the DAQmx drivers.
Could you generate your a simple system report in MAX and attach it please? (File > Create Report > Simple Report).
I suspect that DAQmx updated but you're running a version of LabVIEW other than 2012 with which it isn't compatible. The solution most likely will be to uninstall the DAQmx drivers you have installed and re-install them from the driver CD you use originally.
Kind regards
Chris | Applications Engineer NIUK
(2,570 Views)
