lab view installation Problem
I was using Lab view 2012 trial version.For opening some files it asked for drivers....I inserted older version of lab view driver cd...It got installed.After that there was a problem in using lab view...so i tried to uninstall it from control panel but it didnt got uninstall.I deleted the entire directory from program files.After that i am trying to re install it but it is not getting installed.When i am inserting the CD and installing it ,it is showing that it is getting installed but there is no folder that is getting created in C dive/Program files.When i firstly installed Lab view it took  more than half an hour for installation.Right now it is taking seconds and showing that Lab view is installed but no shortcuts or  folder is actually there in c drive...
Please help i have some serious work to be done on Lab view..
Chandan
(2,364 Views)
Since you have deleted the entire labview from programs directory, sadly you will not be able to run the LV.Smiley Sad
You can try following things:
  • Try to repair the installation using LV dvds or,
  • Try to install a fresh copy in a different drive other than C or,
  • Try installing some other LV version.
And if it doesnt work , you might have to consider formating C drive to install a fresh LV copy.
(2,357 Views)
