labSSH - when using "execute ssh command.vi" get error '"plink"' is not recognized as an internal or external command, operable program or batch file.
getting error while using labSSH - when using the VI "execute ssh command.vi" I am getting an error - '"plink"' is not recognized as an internal or external command, operable program or batch file"...do i need to include plink in the working directory?
(388 Views)
Accepted by topic author Prasad_a85
Got the issue resolved - by adding a path to the putty folder in environment variable "path"
(376 Views)
