labiew with lpc2148 breakout board
Can i use the labview for arm with a LPC2148 breakout module ?, or i have to use a specialized board to use with the Labview ?
Do I need the ARM- JTAG cable to program with Labview, or can I use the bootloader inside the arm processor and the seial port to program ?
(3,117 Views)
Accepted by topic author varunme
You can use http://www.ni.com/labview/arm/  (LabVIEW Embedded Module) for ARM Controllers.
Also for programming, you can call LPC2000 Flash ISP Utility, which automatically invoke ISP bootloader and program ARM controller.
(3,103 Views)
hello, rebice your comments, but the link to the solution is broken, rotted upgrade would greatly appreciate it
I can also program the LPC 1768 with labview, buy this microcontroller for a project but I may have compatibility https://www.sparkfun.com/products/9564
(2,958 Views)
