labview 可以将csv文件格式转存excel格式吗
labview 可以将csv文件格式转存excel格式吗,目前想用labview在csv文件里增加一列数据,用csv格式处理好麻烦,有遇到过类似的问题的吗
(963 Views)
@留白 wrote:
Can labview transfer the csv file format to excel format? Currently, I want to use labview to add a column of data in the csv file. It is troublesome to use the csv format. Have you encountered similar problems?
What's "troublesome" to read a CSV file, add a column and then save the updated data to a CSV file?
  • You could use the RGT functions to create an "Excel" (aka XLSx) file from your CSV data and then use other RGT functions (or ActiveX nodes) to add your new column.
  • As you need Excel installed on your computer to be able to use the RGT functions: there are 3rd party toolkits allowing you to edit XLSX files without the need to have Excel installed, like XLR8.
(952 Views)
你的意思是先将csv文件格式保存为excel格式,然后进行数据处理吗
(907 Views)
