labview 2.2 on Macintosh
Has anyone got a copy on the array palette in function in version 2.2?I need the label for the icon in array palette. While browsing on the block diagram in version 2.2 (which is in hard copy), I have no idea on which array palette is the author using as no description is written by the author. Thanks.
(2,459 Views)
Hot off a rusting Quadra 640: an image of the Array pallette and what's what in LV 2.2 is attached.
There are a few other array functions scattered on other palettes so if what you're trying to identify isn't shown, you may want to scan your hardcopy and post the image.
Fading out. " ... J. Arthur Rank on gong."
(2,448 Views)
