labview 2009 SP1 - Create exe option does not appear
Hello everyone,
I'm using Labview 2009 SP1 and I want to create a simple exe file (to run in the same computer that has labview or in any other  computer with the appropiate labview run time engine).
I create a project with project explorer with the appropiate VI, everything OK for the moment, but when I right click on the menu "Build Specifications" of the project explorer I only have the options New and Help. If I click on New I only have "Source Distribution" and "Web Service (RESTful)" I would like to see the option Application and be able to create the EXE file.
Anyone knows how can i create simple EXE files or make the option "Application" to be visible?
Thanks for advance!
Much thanks for your time and dedication!
(2,421 Views)
I guess you did not install the LabVIEW Application builder when you installed LabVIEW. When you do, it will allow you to create the exe and installer (You must be having a valid licence also).
(2,411 Views)
