labview 2009 save error code 3 : FP heap.
Hello experts,
I'm currently trying to upgrade from Labview 8.6.1 to Labview2009. At the moment, I'm having problem saving vis which were O.K with version 8.6.1.
And it appears a lot of vis affected by this error. I was wondering if it is a bug of Labview2009 and better stay away until it will be fixed? Thank you.
Message 1 of 10
(8,477 Views)
Hi midam,
Would it be possible for you to attach one such VI that is giving this error?
Message 2 of 10
(8,455 Views)
Hi NitinD,
It feels like some of the typedefs are causing troubles rather than VIs themselves. I attached one of the typedef which I still get this save error in LabView9.0.
Cheers.
Message 3 of 10
(8,440 Views)
I was able to open it, although it was looking for some sub controls you did not post.
Spec an Device.ctl
Specan Res BW.ctl
freq range.ctl
 When I tried to save it, I got the error you mentioned.
Perhaps you should try opening those other controls first and update them to LV 2009, then open up this control and try saving.  Start with the lowest control in your "Control hierarchy" and work upwards from there.
Message 4 of 10
(8,433 Views)
Hi Ravens,
I attached one of the lowest ctl. you mentioned. Even this typedef is generating save error.
Message 5 of 10
(8,429 Views)
Hi midam,
I reproduced the problem on my system. I have filed CAR# 186392. I will post any more updates here. Thank you for bringing this to our notice. 🙂
I also attempted to mass compile the controls. But it didn't work either.
Nitin
Message Edited by NitinD on 10-09-2009 09:11 AM
Message 6 of 10
(8,421 Views)
Yes.  You're right.  Hopefully someone from NI can look behind the curtain and figure out what is going on.
Message 7 of 10
(8,418 Views)
The good news is I understand the bug and have a workaround for you.  The bad news is the bug is prolific.
LabVIEW 2009 is unable to save sparse rings with unit labels.  The workaround is to edit the control and remove the unit label.  You can do that in any version of LabVIEW, including 2009.  As long as you remove the unit label before saving it, you should be fine.
Sorry you had to hit this.  Thank you for submitting it -- we will fix it as soon as we can.
Message 8 of 10
(8,374 Views)
Oh, and just in case, here's how you remove a unit label:
Right-click on the control, Visible Items>>Unit Label.  The unit label appears.  Delete the text inside it (in this case, "Hz").
Message 9 of 10
(8,372 Views)
Thanks dhedges
Kudos for you. Hope this one will be fixed in next revision.
Message 10 of 10
(8,347 Views)
