labview 2010 Crash on launch
Hi, I installed Labview 2010sp1 and when I start it gives me this error
"Problem Event Name: APPCRASH
   Application Name: LabVIEW.exe
   Application Version: 10.0.1.4002
   Application Timestamp: 4d2fa7a6
   Fault Module Name: LabVIEW.exe
   Fault Module Version: 10.0.1.4002
   Fault Module Timestamp: 4d2fa7a6
   Exception Code: c0000005
   Exception Offset: 018d7f76
   OS Version: 6.1.7601.2.1.0.256.1
   Locale ID: 1040
   Additional Information 1: 0a9e
   Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
   Additional Information 3: 0a9e
   Additional Information 4: 0a9e372d3b4ad19135b953a78882e789 "
  I can not use it and what can I do?
(2,773 Views)
For Solve this problem, i uninstall framework NI 1.1 and reinstall
Now is all perfect but i have another problem i compile application, and works perfectly in win7 and vista but no in winXP.
winXP open a front panel but any control don't works.
(2,763 Views)
Hello Simx7719,
Thank you for your update about the troubleshooting for the APPCRASH error.
Concerning the second one, did you check you installed the LabVIEW Run Time Engine before deploying your executable? Is there any error message or warnig that points us to any explanation? In what way your application doesn't work? What's the incorrect behavior?
Thank you in advance for your interest.
Have a nice day!
Best regards
Matteo
(2,733 Views)
