labview 2010 FPGA: problem with mean-variance subvi
The subvi "Mean,Variance and Standard Deviation" seems not to work correctly. The calculation of the mean value is ok but std and variance are wrong and the results change with the representation in a unexpected way. Has anyone experienced such problem? Is there any issue with the use of this function?
Andrea
Message 1 of 17
(4,595 Views)
Hi Andrea,
I can't find any reports of incorrect behavior with that node. Please attach an example showing the incorrect behavior and we can verify if there's a problem.
Jim
Message 2 of 17
(4,591 Views)
Dear Jim,
thanks for your reply.
In attachment you find a simple example showing this apparent strange behavior.
Andrea
Message 3 of 17
(4,582 Views)
Hi Andrea,
Thanks for pointing this out. There is indeed an internal overflow problem, which I've reported as a high priority CAR 222056. In the meantime I've converted your node to a subVI and have implemented a fix specific to this particular configuration along with some comments to help explain the changes in case you need to modify it. I'm still testing it and will post something for you on Monday.
Sorry for the inconvenience, and thanks again for bringing this to our attention!
Jim
Message 4 of 17
(4,574 Views)
Hi Jim,
I am looking forward to see and use your fix!Smiley Happy
Many thanks
Andrea
P.S. I suppose there's the same problem for the 2011 Labview version, correct?
Message 5 of 17
(4,554 Views)
Hi Andrea,
That's correct, it uses the same code in 2011. FYI, the problem shows up when the variance is relatively small, and a subtraction that is always supposed to give a result greater than or equal to zero produces a negative number due to roundoff error. The fix increases the internal precision to avoid this problem, and will also allow you to customize it for however many bits of output precision you want to keep around for downstream operations.
Jim
Message 6 of 17
(4,544 Views)
Accepted by topic author skara
Hi Andrea,
Here's a new subVI and test for the configuration in your VI (16 samples, I16 input), saved in LabVIEW 2010 SP1. It's fairly straightforward to adapt it to other configurations, but it does involve reconfiguring several nodes and constants on the diagram. Let me know if this will work for you.
Jim
Message 7 of 17
(4,534 Views)
Hi Jim,
your solution works fine. Thank you very much.
However I have noted that:
1) this new version uses 3 DSP48 units compared to the 2 DSP48 units of the built-in version (I had to modify my application to fit into the FPGA).
2) The number of samples cannot be easily changed to a value different than a power of two. What is a possible efficient implementation of a division by an integer number? Do you have an example?
Andrea
Message 8 of 17
(4,511 Views)
@JLewis wrote:
Hi Andrea,
Jim
Jim, may I ask why you use double casts to divide by 16 and not a single type cast (see image)?
Message 9 of 17
(4,503 Views)
Sure. The Type Cast works fine on the desktop but is not supported on FPGA, due to a number of odd behaviors that don't make as much sense in hardware.
Jim
Message 10 of 17
(4,484 Views)
