labview 2010 compatible with windows terminal server 2003
Is labview 2010 compatible with windows terminal server 2003?  Windows server 2003 is listed, but there is no mention of windows terminal server 2003.
(2,351 Views)
If it's not mentioned, then officially it's not supported. You could wait for someone to respond to see if they have tried installing it. If not, then you could try at your own risk. I don't think there is that much difference between them on an architecture level; I think you should be fine.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,346 Views)
