labview 2012 : Pb with datasocket arising with migration
LabVIEW 2012 and Datasocket :MSI error
I had an application working fine withe LV 8.5 FDS
I migrated to LV 2012  PDS yesteardy in since that time at any restart of the PC , when I lanch my appplication  I get  a message of the installer and then an error otf the MIcrosoft Installer
As you can see in the attached word file, the window event log tell that cwdss.exe.manifest does not exist
It is the case , but I llok to another thread of ni.com called
Why Does DataSocket Server Fail to Launch After Installing LabVIEW 2012? it is told to supress this file ....
So What should I do ?
For information on  other PC where no Pb occur , the cwdss.exe.manifest does  exist
(2,649 Views)
Après une recherche sur « datasocket.LVW16 » sur Google j’ai trouvé cet article,
http://forums.ni.com/t5/Measurement-Studio-for-VC/Inserting-any-ActiveX-control-wants-to-install-Lab...
J’ai ensuite recherché dans ma base de registre (Regedit pour ouvrir l’éditeur du registre) , datasocket.lVW16 puis supprimer les clefs erronées « Inproc32 » qui contenait cette chaine.
Le problème a alors disparu
Par contre, apres 2 lancements arret normal de mon apppli, Labview 2012 se rtetrouve bloqué avec le sablier
(2,628 Views)
Did somebody got tthis Labview freeze Pb ( "wait cursor stay infinitely) when upgrading to 2012
(2,602 Views)
