labview 2017 (x64) hanged importing a shared library
@SZFan wrote:
@dkfire 已写:
Is the DLL 64-bit complied?
If you have used the same DLL with LabVIEW 8.6, I doubt that it is 64-bit. And there for your can't use it with your 64-bit LabVIEW.
Why are you using LabVIEW 64-bit?
No, the DLL was 32-bit compiled.
But I tried Labview 2017 32bit, the same thing happened.
And I also think that Labview 64bit should work fine with a 32bit dll.
LabVIEW 64 bit will not load 32 bit dll's.
Message 11 of 17
(1,756 Views)
There most be:
a) Something specific in the header file that causes the crash, and
b) Some change in LabVIEW 2017 that introduced the crash.
Without the header file, I'm afraid there's not much we can do. Those header files can be really complex, and the Wizard is not a full-fetched C pre-compiler.
Perhaps you can send the header and .dll to NI Support? I think they'd agree with NDA's from your side if required.
I tried the dll wizard once, and decided to keep configuring the CLFN manually. Wizards can be nice, but I find I like the control I have when doing it manually.
Message 12 of 17
(1,755 Views)
wiebe@CARYA 已写:
@SZFan wrote:
@dkfire 已写:
Yes! You are right!
I just checked that the VI previously imported  from the dll file by LV 8.6 worked well under LabVIEW 2017 32 bit. And error occured if it was opened by LV 64bit.
Message 13 of 17
(1,744 Views)
wiebe@CARYA 已写:
There most be:
Thank you very much for your help.
Wizard helps a lot when there are tens of functions or more in a dll library from some company.
I will try to modify the header file and reduce function numbers. Maybe I can find where the crash happens.
Message 14 of 17
(1,741 Views)
Accepted by topic author SZFan
Now I find the reason for which the application hanged.
It is quite simple.
I deleted all notes in the header file and then the wizard worked fine.
The notes leading to crash were like this :
int _stdcall funcname(
                                     int a,          //Characters start with Chinese
                                     int b,          //Characters
                                     float c        //blabla
If the notes started with English words, the wizard worked well. NOTE: The labview 2017 32bit I am using is a Chinese version.
So I am sure that the wizard should have bugs in it when dealing with such header files.
Finally, I'd like to present all my thanks to people who helped above .
Message 15 of 17
(1,738 Views)
And thank you for posting the solution. Please mark it as the solution (press "ACCEPT AS SOLUTION", or we will at some point, but it's really op to you). It will help others to use the forum.
Message 16 of 17
(1,731 Views)
wiebe@CARYA 已写:
Done!
Thank you.
And one more comment: If Labview 64bit was used to import the 32bit dll library ( with header file corrected), no error occurred and no function was listed to be imported.
Message 17 of 17
(1,716 Views)
