labview 32bit and 64bit on the same computer?
Hi guys,
I need to setup a PicoScope Scope with 32bit dlls with my existing Labview-64bit-code. Can I run Labview 32bit and Labview 64bit on the same machine and let them communicate via shared variables?
Thanks Jan
(3,018 Views)
Well, yes, technically, ... but why? What are you trying to accomplish?
(2,999 Views)
I'm currently using a ni scope on a 32bit machine and acquiring data over the network. It slows things down. I want to run the data acquisition on 1 computer to avoid the delay.
I could put the acquisition code in labview 32bit, but would rather avoid that, too.
(2,987 Views)
