labview 5 software migration to modern labview and pc
I have been stuck with trying to move a labview software from an old windows 98 pc to a newer windows 7 32-bit pc. The old windows 98 pc was running labview 5 for this software and it uses a PCI-GPIB/+ card to send and read data to some camac modules. This software has a few packages that it depends on such as NI spy, NI 488.2 1.7, T&M explorer. Currently if I try to run the software with the converted VI's by using labview 8 as an intermediate step errors out on the initial part where it tries to find the 488.2 interface card. I have however installed the drivers for this newer version of labview 2014 32-bit but still no luck. Has anyone had a similar problem or has any advice on how I would migrate this software succesfully? I do not really want to re-do the entire program as there is no time for it. This is a really confusing issue for me since I never used such old hardware and software combination. Please let me know if you would like more information.
Kind regards.
Message 1 of 9
(3,419 Views)
You need to provide the error codes/messages that you get and attaching the code would also help. What is the version of NI-GPIB that you installed now?
Message 2 of 9
(3,414 Views)
Kind regards.
It may be that the GPIB card is not supported in Windows 7.
You need to check that first before you do anything else.
Message 3 of 9
(3,397 Views)
Hi Dennis Knutson,
Thank you for getting back to me. I have attached the error message, I am currently using NI-488.2 14.0 for my GPIB solutions. I have also attached the VIs in a zipped folder with the required libraries. The main VI is banc-test-cables-Atlas-CERN-2006-02-21. Please let me know if you require more information.
Kind regards.
Message 4 of 9
(3,386 Views)
Hi nyc,
I really hope that, that is not the case. Although I am using the pre 2003 NI PCI-GPIB card so it may very well be the case. However I can see the card in the windows device manager and the NI-MAX and NI-VISA see it aswell with no problems. If it does turn out not to be compatible then I also have one of the NI GPIB-USB-HS interfaces lying around. Perhaps I could use this instead but will I have to reconfigure the VI's signifcantly? or will it work without modifying the VI's ? and also I need two of those interfaces for full deployment, hopefully I can debug the program using just one and if I am confident enough I can find another one somewhere.
Kind regards.
Message 5 of 9
(3,380 Views)
@santib77 wrote:
Hi nyc,
Kind regards.
Having used the NI GPIB-USB-HS adapters recently I would try to avoid using them ever again.
Message 6 of 9
(3,371 Views)
The error had nothing to do with gpib since it is being thrown by the new file function. As the message states, check your path.
Message 7 of 9
(3,361 Views)
Hi Dennis,
Thank you for pointing this out to me. Luckily this was the source of the problem and not the migration to a newer platform or gpib communications. The software now runs perfectly as intended. Now for a final  question, this software will eventually be needed in a remote place where it would be much easier to interface with a laptop instead. However laptops do not have the pci-gpib card for the interface so if I were to use the usb-gpib adaptor do you think it will work with relative ease? I understand nyc has already shed his thought on the matter, but perhaps you have a different experience. Many thanks again!
Kind regards
Message 8 of 9
(3,309 Views)
The change to a USB type converter should be absolutely transparent. It's the same driver and the same functions. Many problems are associated with power to the hub and that is a Windows configuration.
Message 9 of 9
(3,293 Views)
