labview 6.1 stability
Sorry, I have to repost this question as I sent it in the wrong place.
The question:
I installed lv 6.1 on a windows 98 system. As I am having problems of stability (frequent crashes, much more than with the former release 6.0), I would like to know if there is some specific problem with windows 98 or there is some patch available.
(3,044 Views)
Well, Windows 98 isn't all that stable to begin with... But, how much RAM is in your system? What kind of system do you have? Just for info, I run on a P4/2GHz with 256MB or RAM under Windows XP, and haven't run into any stability issues.
-Saverio
(3,044 Views)
Thank you for you comment. My system is a P4 1.6GHz with 256 Mb RAM.
(3,044 Views)
One other thing to look at; are you getting any error codes when you have a crash (typicaly a pop up box with the error code displayed). You can also look at the LabVIEW error log. The log location is described in the knowledge base, document id 2PBCSFDW. You can look these codes up on the NI website and possibly get a solution to the crashing problem. Good luck.
Steve
(3,044 Views)
