labview 8.0.1
I get a full system crash whenever I try to mass compile after installing LV 8.0.1 on my PXI-8186.  I have 2 other non-NI machines which have not experienced this problem.  Has this happened to anyone else?
(3,373 Views)
Interesting to hear.  We have had similar difficulties with a PXI-8187.  Do you know what was compiling when it crashed?  Also, what modules/toolkits do you have installed?  RT? FPGA?  NI is trying to help, but has had difficulty reproducing the situation.  The fact that it does not happen on generic PCs may help.
(3,311 Views)
There is a known issue in the mass compile after installing the 8.0.1 update if you have NI-DAQmx installed. Please see the following KnowledgeBase entry for detailed information.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,290 Views)
