labview 8.5 and dpo7254
i am currently using a tektronix DPO7254 oscilloscope for data acquisition controlled with labview.
i will explain you my problem:
the idea is to acquire (at least) 100 waveforms per second with labview 8.5;
i made a programme with the ready-to-use vi's for the DPO7000 series from www.ni.com..
(http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=8903)
i have the following settings:
DPO7254
sample rate: 100Ms/s
horizontal scale: 10µs/div --> horizontal range: 100µs
so, according to those settings, that should be 10000 samples per waveform, resulting in 10ns/pt
triggering is made with a given trigger (on another channel), synchronized at 100 Hz,
which means that there is a triggering signal every 0.01 s
theoretically i should acquire every 0.01 s a waveform (in 'single shot' mode on the scope),
resulting in 100 waveforms per second..
actually i receive a waveform approx every second, so it takes me ages to acquire 100 waveforms..
(according to the data sheet that scope is able to acquire 250,000 WFMS/s..)
is that problem related to the slow GPIB connection between the scope and the computer?
are there any hidden time-delays in talking/listening mode when using labview?
do you have any solutions to that problem (acquiring as many waveforms as possible in a short time)?
best,
E
(2,885 Views)
Hi Eric,
I think the problem is the speed of the GPIB. Maybe it would make sense to use HS488 in your case.
Apart from that here you have a KB, with information how to speed up things. This is related to HS488 as well, but maybe you can adopt some things.
Best regards, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(2,849 Views)
